Tank Options for 750C
bauer4
Whatever!
Can anyone tell me if any other 750 model tanks will fit an '81 750C - I did a few searches and couldn't find any other discussions on this topic. Thxs
Your choices are pretty limited because of the wide backbone on the DOHC frames. Other DOHC tanks from 79-82 will fit. I think the F tank looks pretty decent if you cut the tabs off.
If you're looking to buy aftermarket, there are only two options that I know of, and neither are cheap. You could pay too much for a composite tank from Benji's that is of questionable quality, or you could kick in a couple hundred more for an alloy tank from Roc City Cafe. He's got a buck for the DOHC frame backbone. I think the custom may dip a bit more in the seat area than the K/F models though, but it should still fit.
http://www.roccitycafe.com/
There's also an ebay seller (neuxstone) that supposedly has some tanks that fit, but I haven't heard of anybody using them and I don't want to be a guinea pig.
Early SOHC tanks will fit IIRC. I think 75/76 and before are just wide enough to fit over the backbone, the 650 tanks can fit, but need to be pounded out on the bottom.
Thanks much - I will look into all those options. I knew the C wasn't going to be easy to mod but the price was right and there's nothing like a good challenge. I am going to go more towards the street tracker look I think. There is a used parts dealer in Denver so I will likely drop in there and see what's available.
Actually, the stock tank on an '81 custom wouldn't look bad on a tracker with the right paint scheme. Just my opinion.
