This usually varies from bike to bike. On my own bike, i just cut the original shift lever down and drilled a hole in it. You could do the same with yours if need be. Then you could put the proper bend in it, if needed.vw121 said:Will I need an offset shifter arm to install these?
teddpage said:This usually varies from bike to bike. On my own bike, i just cut the original shift lever down and drilled a hole in it. You could do the same with yours if need be. Then you could put the proper bend in it, if needed.
