snmavridis
Gettin my life together. One bolt. At a time.
And I don't know what's wrong. Now that I have your attention, if you've seen any of my build posts you know my bike doesn't want to start. I rebuilt and rerebuilt my carbs, I commissioned work on my carbs twice, and so i don't think it's a gas issue. I tested compression and got readings between 110-140, not TOO BAD for a bike that's been sitting a while. So compression isn't on my radar.
It's gotta be electrical. So I tried to redo my points and ran into issues. I'll post a link to that thread if you're interested. Which got me saying "screw it lets redo the wiring harness, test the electronics and go from there".
First test is if my coils work properly. I plan on doing the bench test sonreir has so elegantly laid out in the sticky, but I figure try the easy route first with a multimeter. Continuity between the leads on each coil seems alright. Attached are the results. When I attach the multi to the lead and spark plug cap I get no reading. I've tried every combination of each of the four leads, each of the spark plug caps, and every setting on the multi. Keeps giving me a null reading.
Are my coils messed up or am I an idiot?
