testing the charging system?
locOleoN
Im no electrical whiz so I have a question that mabe you guys could help me out with...
First the facts:
- 75 cb550f
- new wet Battery (Interstate 12N12A-4A-1)
- Fully charged on the trickle charger/maintainer at 13.2v & stablizes at 12.6v
- Battery drains after a few weeks to 11.5v after a few rides.
- the charging system on the honda's are known to SUCK big time so
The Problem:
I suspect that that my charging system (regulator/rectifier), is not charging the battery as it should
I understand the very basics:
- Rectifier converts AC to DC
- Regulator maintains a constant voltage level by comparing the the actual voltage output to some internal fixed reference then adjusts.
- I know the location of each piece on the bike.
The Question:
1. how do I test using the mulitmeter that I have which piece is not working properly to determine what I should replace?
2. has anyone built their own regulator/rectifier from aftermarket components to replace or compensate for the old weak charging technology?
Ive included a pic of the tester that I have.
I suppose I could just call and ask Tony, but I want to try to figure it out myself, and Id like to have any answers posted on the board for everyone's reference when the same question comes up again...
Thanks
n
I'm in the same mess.
I seen on the net somewhere a complete replacement system for honda's which apparently correct some of the known issues. It comes with a new regulator, new rotor and stator.
For the 750 I have, the biggest problem is the rotor, which is one of the more expensive parts. I don't know how you would test that on the bike because it works together with the stator and brushes.
I'm trying to make a rectifier/regulator for my bike but it's gonna take me a bit to sort it out. out of curiosity could you measure the AC voltage accross any 2 of the 3 wires from the alternator? mine seems a bit high but it could be normal; I have nothing to compare it to. If I figure it out I can make you one.
Just some interesting points from the SOHC guys when I posted the same question:
http://forums.sohc4.net/index.php?topic=38585.new;topicseen#new
those boys are a wealth of technical info!
I dont know if this would help but I measured the different volts at these different RPMs:
I wired up a headlight & lights kill switch so it was easy to test the with the lights on & off:
Headlight Off
- engine off, key off = 13v
- idle (1000 to 1500 RPM) = 12.5v
- 2500 RPM = 13.2v
- 3500 to 4000 RPM = 13.8v
- 5000+ RPM =14v
Headlight ON:
- idle (1000 to 1500 RPM) = 12.1v
- 2500 RPM = 12.7v
- 3500 to 4000 RPM = 12.6v
- 5000+ RPM = 13v
I learned with my CB550 that crawling around the city doesn't adequately charge the battery. I had installed a headlight switch and it helped. I have a switch installed on my XS and ride with the headlight off most of the time.
