The $100 Suzuki T500 ground up Cafe build.
OCDCustoms
Evening all, my name is Byron, hailing from Sydney, Australia.
Wanted to document this build from the get go, but got about 3 months in and then decided to get my ass into gear and throw up a thread!
So, story goes, while helping my father load a purchase of concrete pavers from a landlords rental property, a bit of sleuthing revealed a boat and a (at the time) unknown motorcycle sitting in sodden leaf litter and Ivy, under a tarp, both in incredible states of disrepair.
I had been getting itchy wrench hands for some time, and something in me said, "buy it off the guy for shits and giggles, and see what happens".
I had absolutely no idea what it was at the time, as I could only see a headlight, and the front end of the bike poking out, but took notice of the flat bottomed headlight.
Some googling later returned pictures of a devilishly good looking Suzuki T500, so the next week, I was at the blokes house, with a bill in hand and a ute in the driveway.
Once I returned home, I properly surveyed the new purchase (or burden?) and very quickly and quite violently threw the hope of a resto right out the rusted, dirt encrusted, wasp nested window.
But I just couldn't let her go. My hands started working feverishly tearing her back to a bare frame, and then it all happened............
My apologies for the pitiful Instagram/iPhone image quality, they will get better now that I actually have a thread up.
I won't flood this thread with photos in its first post, but some work carried out so far:
Shaved:
*Rear frame extensions
*Rear fender mounts
*Centre stand mounts
*Oil tank and side cover tabs
*Seat pan mounts
*Steering lock bracket
*Unused tab under head tube / main rail junction
*Smoothed grab rail nuts
*Removed unused LHS brake pinion
*Cut down footpeg bracket mounts
Misc:
*TR Style frame bracing
*Removed, rebuilt and re welded rear set bracket braces
*Reshaped main rail / cradle gussets
*Custom made battery bracket between rear shock mounts (ultimately under seat)
More to come......
This should be good.
Thats pretty far gone my friend I cant wait to see what you do with it!
Welcome!
There are a few of us with Titan Cafes here. I have yet to put up a build thread for mine yet but I hope to soon.
There is a lot of weight that these girls can lose and they are conservatively ported, so there is a lot of potential to make them go.
One thing I am doing with mine is replacing the 19 inch front rim with an 18 inch, both front and rear are alloys. I have all the parts not to convert to a dual drilled disk setup too. The lig
You might want to consider these mods as well.
Cheers gents,
Agreed it is heavy task ahead considering i can only re-use the frame, rear hub, swing arm, triple clamps, front brake backing plate and approx 80% of the motor!
Very excited for the work ahead in saying that.
Thanks for the advice CarbsAndCylinders, the 18" front wheel+alloys are a go and I don't think i could possibly strip more weight out of her!
I will be keeping the drum front end, as i would like to keep her semi-period.
Would love to chase down a GT-750 4LS, as everyone does, but they are relatively thin on the ground here in Australia.
Some more snaps attached.
Few more random snap shots.
Been moving forward at quite some pace.
Rims MAY need replacement, maybe? Thinking flanged Akront alloys F&R.
Cut out the bent and misaligned rear-set spur and replaced with 3mm plate gussets.
Got my coal miner face on getting assorted alloy items back up to scratch.
Re tapped most of the M10 fine pitch threads to suit far more readily available coarse pitch bolts.
Smoothed and filled the factory fold-cuts in the kick-stand bracket, bead blasted the whole kick stand assembly, and cut re made the toe-peg for the stand leg.
Re-built the oil pump and sorted out new stainless hardware.
More to come....
This build shows SOOO much promise - I absolutely love to see people re-finish and polish up a bike that most folks would be too chicken-shit to tackle. It's inspirational - especially since my own project bikes are now fire damaged - truly inspirational. I hope there's more to come and SOON!
You see here kids he got the grinder out and started cutting :o and no one said a thing :) because he can only improve this bike ;D unlike some builds here . OH nice find and great work
Anyone on this know how I go about getting flanged alloy wheels on my 75 Titan? If I order WM3 Akronts or similar that are pre-drilled (say 2.15x18) for the rear (1.85x18) front, will my stock hubs and spokes mate correctly to the new flanged wheels?
thanks
You have my attention too......looking forward to seeing what comes of this project. You certainly started with a pile of shit. All the more satisfying when you turn it around though.
Good work so far.
