So after my previous thread here about how my motor was spitting out bits of metal in the oil, we ended up pulling and opening the motor. Cam chain tensioners were old and weren't doing their job, so the chain was slapping against the top cover. Oil starvation in the top end meant the rockers were grooved and a lot of the metal was burnt. Decided to buy a new motor, got a relatively clean motor for $150 and threw it in the bike. Changed the starter motor over because the new motor's starter motor was pulling too much power and draining the battery, and after a bunch of other work, she runs again without leaks.
Now to the new problems:
Took her home from the shop today, she didn't start up as well as with the old motor but I'm waiting to see how this plays out after I ride the bike for a while, get the battery charged up and all the dust cleared out, so to speak. However, I noticed that the revs would slowly drop when I was stopped at a light in first with the clutch in. I felt like the bike would die and I was worried of what would happen if it did, so I kept a little throttle on it so the revs didn't fade away. Made it home doing this the entire time, and as I pulled into my lot I cruised forward in first, and as I suspected the bike died. I'm wondering if this could be an idle adjustment I need to do tomorrow when the bike is warm, or if it could be something else. I filled up with gas on the way, and she did start up again after filling up, but same issue with throttle, had to play with the clutch a lot more at stops. Anyone have similar problems or any ideas?
