The giant killer
She was sweet...... made power up to 12500rpm and would make your feet go numb if you rode under 8000rpm for any length of time.
I gotta ask, what was done to the engine to turn out 49hp at the wheel? From what I've read, that's a shit load for a CB350
Steve
It may have been 47hp if I remember correctly.....
Pistons were Henning's 363cc(I think) with compression at around 12.5:1.
Cam was a Megacycle with the full drag race/hill-climb grind. The lobes were so huge that I had to hog out the cam box to get it in and make a new oil baffle to clear the rockers. I think I had to mill material off the bottom of the cam box to clear the lobes. Didn't bother with roller cam bearings or roller rockers but made sure all of the stock parts were new.
Crank was stock but new and made sure it was perfectly true. Flywheel(alternator) was removed and ran a total loss ignition. Ran both points and electronic and didn't notice any difference.
The real "work" was done on the head. It was ported on a flow bench but we probably just got lucky with the combination. Larger valves with stems turned down and 3-angle valve job done on a brand new machine. Racing valve springs with titanium keepers.
The cylinder was milled and bored true and had a groove cut into it with a copper "o-ring" installed to bite into the copper head gasket to keep all that pressure contained.
I pretty much left the head in the capable hands of a guy who was an accomplished superbike race motor builder. Again, I think we got lucky with the porting.
Carbs were Mikuni 34's that were jetted depending on weather with a Gunner Gasser 1/4 turn throttle.
The exhaust was built specifically for the engine's specs with only the minimum baffling by an exhaust expert(any vintage racers will recognize his work).
Ran very thin synthetic oil to minimize drag. In an old machine that meant having to wipe away the oil that weeped after every riding session.
I ended up with a crank bearing failure and replaced the crank with a used one but a tired crank was not up to the task and it failed in short order. I found out the hard way that a motor in this state of tune can be safely run for 2 seasons. It grenaded three quarters of the way through the 3rd season when a piston broke at the pin.
Wow indeed, one hell of a mill there. Guess that's a little too much of a pipe dream for me though, need my lump to last a little longer than two seaons. ;D
Impressive none the less!
Steve
Nice use of the CB500T tank - still want to get my hands on one of those tanks someday.
Roustabout said:
A few pics of the old giant killer... 350cc... 49hp at the rear wheel
Looks like my first race bike!!!! great minds think a like it would seem. I used to race mine in the classic and the forgotten era class. As you said giant killers. mine had full track joy cam, modified cam box ( so it would fit !!) gass flowed and big carbs. lots of fun. Used to ride it on the road between race meetings ;D :D ;)
Had to put road silencers on it or it was to noisy, it also got a disc front end later. was a pig below 6 thousand but above that it was sooo wild. Had so much fun in the eighties finding LC 350,s to embaress.
sorry for the bump...
but i gotta ask how you kept the bike idling without the flywheel.
also who did your crank work?
The bike idled fine considering the cam that was in it. I trued the crank myself. There was no other fancy stuff done on the crank.
