Yeah I noticed the little hook of the springs at the rear facing up - will definitely flip them over
Not really sure of the colors on this bike yet. Been a real struggle to sort it out in my head. All the colors I like are muted greys which are essentially the same color as the bare metal. So might just clear the entire thing, frame and all.
The engine is completely bead blasted - no polished bits at all. I'm going to be shaving the front forks of all the fender and caliper mounts - will leave one bottom caliper mount to bolt the brake stay to for the front. The fork lowers will just be sanded to a brushed finish to match up with the fork covers which are bare steel.
The tank(s) is likely going to be a split affair - two separate tanks sitting on L shaped brackets welded to the backbone. You won't see them from the top and the tanks will sit on them bolted on from below. So the tanks will just float there with the backbone of the frame between them.
I might sell off the ribbed ducktail 7 West aluminum rear fender I have now and replace it with a plain steel version. Would like the option of adding a pillion seat to it like this one:
http://www.ebay.ca/itm/LYCETT-TYPE-PILLION-SPRUNG-SEAT-FRAME-SPRINGS-BSA-ARIEL-ENFIELD-ECspares-/261070235190?pt=Motorcycles_Parts_Accessories&hash=item3cc8ffa636&vxp=mtr&_uhb=1#ht_2618wt_968
