The most ridiculus problem...
gsdapollo
OK, so i stripped my bike down to the bare frame a few weeks back and have had my motor sitting on its side on a dolly (might not have been the smartest idea...). I went to start cleaning the motor up today so i can paint it, went to put the oil filter cover back on and for some godforsaken reason, the bolt wont go in all the way. I have checked the hole the bolt goes in and no obstructions, the bolt itself is clean, and I've even checked the manual to make sure its the right bolt (big with lots of holes). I mean seriously, it's as if the bolt mysteriously grew a half inch. I've been messing with it for about an hour and I can't figure it out. I put the bolt through the cover, then the spring, then the filter, made sure the cover is on the right way, and it stops a half inch short. I've tried it with just the bolt and im stumped... or retarded... Its an 84' 650 nighthawk btw...
I posted this on the nighthawk forums as well, just covering all the bases.
stripped thread? gunked up threads? i say run a thread chaser through it then clean it out thoroughly.
crazypj said:
You do have the oil cooler spacer plate in place?
PJ
lol, yep that was it... The reason I never even thought of it is because the oil lines running up to the cooler are attached to that plate as well and since the motor is out of the frame, i had the plate with the lines still in it sitting on my work bench as opposed to where it should be when the motor is in the frame. Of all the times i changed my oil i never really even noticed the plate was there so go figure i was a little confused when the bolt didnt just go back in lol... thanks though!!
PJ
i get the feeling you speak from experience on this one ;D ;D
ive done the same thing on a couple of other non-bike related things. spent time trying to figure out why it wont go down all the way only to realize your missing a part of the assembly :P
