Bradj, RD350 to beat a T500. Easy way is to slip huge jets in your dad's bike so it blubbers. RD will weigh less - hope you weigh less than your dad - that's free HP.
Do you need to get a TZ750 top end, 36mm carbs and a set of Swarbrick race pipes - that's an easy 65-70HP or a TZ350G with 6 transfer ports, 39mm flatslides and Swarbricks for 80+HP. Not a cheap option but nice HP.
For the 350, we should be thinking big carbs, RD400 transmission, big ports, RZ reed cages or ported RD cages, carbon-tec or Boysen reeds and a set of custom pipes designed in the mid west and fabricated out east. I know a guy with slip rolls that can weld and another guy that can probably design a decent set of pipes to match your ports.
For a drag strip run, you could go with higher compression and race gas too. Your dad doesn't need to know ;-)
Have you ridden an RZ? They are like an RD but better in every way. Not as cheap as an RD to start but you start with more HP and they can be made to look and run amazingly well.
