THE RD FROM HELL
Well i wasnt going to say anything about the hair but.....
Fuck The Nay sayers bro keep doing what you do ;D
As I sit here under this shade tree I'm here to tell y'all what's wrong.... Just kidding. :-)
My only comment is about the length of that swingarm - It's long. Any idea how much that will add to the wheelbase? Frames with long swingarms typically have the swingarm pivot further forward and we probably don't want to talk about what that might involve. :-(
It might be possible to heat and bend both front and rear downtubes to pull the engine cradle/pivot forward a few inches. But before you start down that path, what is the wheelbase now?
Too long im toying with a plan to cut out and rework the center brace of the swing arm so the wheel will fit then i can shorten the arm if my axl slot starts where the current slot ends im the same as a rd400
Just measure the wheel base - axle to axle and then you will know and knowledge is power. You'll be able to make an informed decision.
And those USD forks are probably 1/2" less offset than stock and if the front end is lower that shortens things too.
Ha wonder whats going on here
You know I'm totally stealing all your ideas, right? ;-)
seriously though, I would like info on what parts you put together to make that rear wheel...
The last picture of a rear wheel is just some 18 inch dirt bike rear i have no idea what bike its off of yz mabie. the wheels i built are high sholder xs650 rear hoops and 98 yz250 hubs and spokes
Brad, do not look at this thread..
http://www.2strokeworld.com/forum/index.php?topic=18252.15;topicseen
CNC machined water cooled RD400 motor machined from a solid block of aluminum. The original bike did 164mph at the salt flats
With that sort of expertise it would be possible to add whatever extra ports or power valves you wanted. Head spinning.. :-)
two-smoker said:
Cool. That's the wheels I meant. So the YZ hubs are 36 hole? Good to knew.
i got to get with some guys to nail down exactly what year and cc the yz its off of so i can get a proper sprocket made ill post that info once i have it
Well hot off the mill my jugs are cut my arms are gonna hurt tomarrow
Looking good. If only you had a set or race ready high compression R5 heads to try on that motor ::)
Fresh reeds are always a good idea too.
If it survives the drag race against the T500 we will hopefully see it at Mid Ohio or Barber or both. Or I am just riding to Frostburg when the snow leaves.
Ill meet you there mike ,got to see this beast !!!!
