The Snowball Effect....or, optimizing a CB550
scott s
Over 1,000 Posts
DTT BOTM WINNER
I was planning on building up an engine for my next 550 project. You know, MRieck head, cam, high CR pistons, etc. etc.
After adding up the cost, I figured I was awful close to just getting the race engine that Justin has for sale. Justin was even kind enough to answer a bunch of questions for me (sorry for wasting your time, Justin :( ), but even after "de-tuning" it, it would still be pretty high strung for street use. Plus, I quickly surpassed the cost of the ZRX1100 I sold last year....you know, a 115HP bike with double the torque of a modded 550!
I originally wanted to use a 550 based cam since I have a set of early style small face gauges that were on my very first SOHC4. A bit of nostalgia. That means a hard weld cam, which leads to hard welded rockers, better springs, oversized intake valves, etc., etc. Then I need high CR pistons and an over bore. Machine shop work. Might as well add in an adjustable cam sprocket now. It just goes on and on.....
Then it hit me that I could easily buy a bike that would walk all over this modded motor for a lot less money. Yes.....I know we do it for the love of the bikes and as a hobby and the dollars spent don't really count. ;)
That's when I decided to just freshen up the stock 550 I have and spend the money on suspension, brakes, tires, etc. We're talking a couple hundred bucks for rings, lapping the valves and some gaskets and I can do all the work myself.
But what about maximizing a stock 550? Maybe spend ~$500 for a Stage 1 head and keep the stock valves, no need for hard welding, etc. Have the head milled to tighten up the deck just a bit.
Then I saw the Cognito Moto GPS speedometer and realized that's pretty cool, too. That would allow me to run a 650 cam and not need to swap tach drives.
So....to make a long story longer....what about these things on a STOCK 550 engine? Worth it? A waste of time and money? Will I notice it?
1) Stage 1 MRieck head, stock valves, springs, etc. Should be plenty for a stock or CB650 cam.
2) Mill the head to tighten up the deck .038-.040" for better squish and a slight CR bump. Is this a good idea with stock pistons and valve reliefs?
3) Adjustable cam gear. It's only about $40 plus the time to learn how to dial in a cam. I've heard that these engines can benefit greatly from optimized/advanced cam timing.
4) 650 cam (dang it....I just sold one a couple of months ago). I've used them before and my butt dyno says that work. If doing the above mods and I don't care about the tach drive, is it worth spending ~$100 or so for a little more cam? Will it work if I tighten up the deck?
So, basically, just optimizing and blue printing everything above the cylinders. Some fresh rings and gaskets. What do you think this would get me out of a stock engine?
Don't forget riding ability. I've seen great dirt riders get on a little "nothing special" bike and lap everyone else. On the street, shifting, the way you take turns, the line you cut... so sometimes all the mods aren't needed.
