The Workshop & Deck
Re: Workshop, The bench rebuild
Bert Jan said:
Tight work there mate! Looks killer! Now build some BOTM winners!
Haha I know right! ;D put all this work into the build place better push out some pretty sweet rides 8)
So I'm taking a 4 day weekend to finish up a few things so I can get back to bike builds ;)
the plan
1: put all the finishing screws in the walls
2: paint 2 coats of undercoat
3: paint 2 coats of topcoat
4: finish siding
5: finish flashings
6: finish sorting out workshop boxes
7: install av rack
8: fit off all av cables
and what ever helps get it done!
Ill post up monday night how its allgone :o
1: put all the finishing screws in the walls Tick
2: paint 2 coats of undercoat Tick
3: paint 2 coats of topcoat Tick
4: finish siding Tick
5: finish flashings Tick
7: install av rack Tick
I have also test fitted the split system head and cut related holes and finished the door frame.
Still need to paint the floor, install lights, have power fitted off and connected, mount work benches, build shelves, install guttering and down pipe, stain ply on wall unit + door frame + legs on work benches. but in the scheme of things I think im on the home straight ;D
Re: Workshop, 4 day weekend to break its back!
and walls finished
flashing came up sweet
av swing frame rack and split system head
door frame sorted
Re: Workshop, On the home straight?
Ok finished early today, so I came home to tackle another of those little jobs :)
I'd scored a couple of bar stools, both needed to have the cheap covering replaced and turns out the sponge wasn't much chop either :( lucky for me we had some felt covered sponge at work that I could use and there was some material saved from when I trimed out the motorhome :D
So I pulled off all the old stuff, cut and glued the new sponge on, stapled the fabric to them & Bam 2 comfy bar stools ;D
A man gotta have his thinking stool ;)
absolutely ;D those are for guests, this is my thinker ;)
Great work, and great thread.
My personal preferrence would have been for a light varnish on the plywood walls, but I'm not paying your bills, so you get to choose ;)
I love the way you've provided for lots of power socket outlets. Can't have too many - or too much lighting. I remember when my late Dad had the family home built (1970-ish) he included his man-cave in the design - it was 12m x 12m, had a double French door entrance, and double switched socket outlets mounted at 1m intervals around every wall - within 2 years he was stringing extension cables across the ceiling!
Don't forget to keep that compressor tank drained (and regularly inspected).
Papa Smurf
Papa Smurf
Thanks mate, Your the 2nd person to suggest the varnished wood look, and although I do like the wood look I wanted to go for a more modern professional style... However the Tv/aircon/compressor cabinet & the door frame are going to be stained the same as the steel topped workbench to give some contrast. I'm glad your enjoying the thread.
Bit of an update, I've been flat out getting things squared away so I haven't been posting, but by mid next week I will have a massive update with tons of pic's for you all to enjoy ;D
heres a teaser for you till then ;) cheers Andy.......
