Thin insulation / cushion material needed
Tim
Administrator
Staff member
So - I'm planning out my electrical for my rigid XS650.
Ordered up the teeny tiny 2 x 2 x 3.25 inch Ballistic EVO2 50 battery. I'm going to mount it where the starter motor used to be on my XS engine (bottom rear of engine).
Planning on fabbing up a simple metal box which will mount to the engine using the starter motor mounts. Looking for material to wrap the battery in to keep it snugly in place, protected a bit from vibration and insulated from the heat of the engine.
Going to mount the regulator/rectifier to the exterior of this little box, so all the electrical will be neat and tidy.
How about that thin rubber cushion stuff that they sell to line tool box drawers? A roll of that stuff is real handy to have around the shop anyway.
There is also some thin rubber carpet padding out there that might be just the thing.
I have an old wetsuit I am cutting up for when I need something a little thicker.
Will read up on Dynamat - I'm likely over thinking it - just a little concerned about the heat mostly on the battery.
The battery won't produce heat (I run the same one on Gretta), but the motor will. Dynamat is a great idea. That's what it's made for. A sound/heat barrier. On gretta I used the foam they put between camper shells and truck beds. But it's in the tail with no heat.
Re: Re: Thin insulation / cushion material needed
Tim said:
So now I just need to find a few square inches of the stuff :)
Let me see what I can do for ya there!
