I just did this on a 76 Honda CB360.
It was easy, just took the air filters, seat and tank off and it was done within an hour. Followed the same path, replaced the worn out cable ties etc.
Be prepared for a few male to male, female to female problems. I used adapters from the old harness to allow for these connections. My signal relay also had to be relocated from the front of the bike under the ignition to where it is now, which is next to my battery. Don't ask me why but the wires just went different directions to my old harness for the relay for some reason.
This is why I replaced my old wiring harness. It was a mess:
That is Go's hand in the photo by the way. Mine are not so.......girly.
now that's a loaded question...
In theory if you have the right year harness for the bike and all the connectors on the components are good then the swap: unplug and plug should be an hour at most... (again if all the stars, moon and planets align..)
it could be a full day from start.. Remove tank.. To finish.. Restarting the bike..
