thinking about making a couple tools
rockcitycafe
I make things.
I was thinking about making my own valve seat cutting kit, as I have a 400f and 750 motor that I'd love to build into race motors. question is: i have a lathe/mill combo, a smithy, and have built my own fly cutter using carbide inserts, so what I wonder is 1: can I build a decent tool set with this equipment and 2: can I recut the valve angle as well with the lathe for good results??
this kind of machining really requires pretty specific tooling. You may be able to get away with the valve work in a toolroom lathe but not any combo machine I've seen.
To put that into perspective for you, I have a Tree 2UVRC mill and a rebuilt Logan in roughly 17x40 flavor and I wouldn't try it on them......
You decide amigo. For almost all other work I think you could make it work.. Sorry man.
I wouldn't be refacing valves, the hard surface is generally too thin on anything made after 1976~77, particularly on intakes. (0.002"~0.003")
The exhausts may be around 0.008"~ to 0.010" stellite face when new.
You need to know minimum margin thickness, it may be possible to take a thou off although I don't like running too close to minimum thickness (valves can distort or crack)
Neway make a valve refacer but its about $3,000 doubtful lathe is rigid enough, unless your using a collet into spindle?
Multi machines tend to have pretty flexible toolpost mounts so your likely to get chatter.
It would probably be possible to make an angled holder and use Neway inserts, normal cutting inserts will have too much surface area and will cause chatter.
PJ
I have seen valve grinders go for a few hundred bucks at farm consignment auctions. I have seen valve seat grinders go for a hundred on Evil-bay. Usually new stones need to be bought because the used ones that come with it are worn out. If you plan to do alot of this work, get a name brand machine like sunnen. Sometimes you can get away with lapping the valves and valve seat. The only way I could see this being done on a lathe would be with a tool post grinder ($200 on ebay).
Take a look at Neway cutters.
They are real expensive but they have replaceable carbide inserts.
Do you mean re-cutting actual valve face?
Not usually a good idea on anything made after about 1976~77 as surface treatments were pretty thin.
You'll probably need a collet and drawbar in headstock to grip valve stem without damage (remove chuck, probably #3 Morse taper?)
It also makes a much more rigid set up
