born2expire
let's talk shop
http://www.boatmasters.com/evinrude-gasket-sealing-compound/
yes i know this a moto forum, and yes i know this is a marine compound. I recently had the chance to attend Honda outboard school for work and the master tech in the class swears by this stuff. As we were disassembling and reassembling the outboards we used this stuff everywhere. Mostly on all the bolts and on your gaskets. With the bolts this stuff virtually seals off the metal from corrosion and heat so they dont get hard, corroded, loaded with dirt and when your taking them apart they won't snap off anywhere. Also we used this stuff on the gaskets as well. It acts as a great sealer and when you use it on both sides of the gasket it will prevent the gasket from becoming so hot that it gets stuck to the sealing surface, so to prevent future scraping and possibly getting gasket material down in your engine throw some of this on there so next time you open up the engine you just wipe off the excess from the sealing surface hit it with some new sealer and away you go. I just ordered two cans of this stuff from this website and it's a steal so i will be throwing some of this on the 125 and 360 when it comes in. Anywhere you think dirt, water, or corrosion will happen you can use this stuff except the fuel system (i.e injectors) its almost like a slimy peanut butter and a little goes a long way. I know i always love to learn something new or a product that will help so i needed to share the wealth. If you have used this or something similar please share your story, thanks.
