Thoughts on your XS650
Re: Re: Thoughts on your XS650
atx360 said:
I think its funny how everyone Tries so hard to be different instead of just building a bike they would enjoy. I do it myself, not bashing. Just reminds me of a saying I heard once......."all you non-conformists are all the same"
Sent from my SAMSUNG-SGH-I997 using Tapatalk
So true, i just want a bike that looks good and i look forward to riding :)
Swivel said:
Neat bike,I think its a D model.Put some good brand of oil in it and fit a new clutch cable and lube the handle lever pivots with some moly grease.If its got old crusty tires fit and balance some stock sized Bridgestones to keep alive.
Yeah, my hand is a bit sore from the clutch lever being so stiff, and she's impossible to get into neutral when stopped, gotta throw it in while i'm rolling. is that common?
I'm not an expert on anything, but I do know a bit about XS650 clutches...what you're experiencing is NOT normal.
The clutch systems on XS's are needlessly complicated, as you'll discover by doing some internet research, but right off the bat, lube the clutch cable, make sure it's not binding, and take off the left hand clutch cover so you can clean and lube the worm gear that activates the pushrod that traverses the engine and operates the clutch...many owners never touch these components, which can lead to a stiff clutch.
Check your clutch play.
And...you may have to drain your oil, take off the right hand engine cover, so you can check your clutch springs, and probably end up disassembling the clutch basket assembly, taking a file and dressing the ridges on your clutch basket.
When I first got my most recent XS, it went from being almost unridable, impossible to get into neutral at a stop, and with a dreadful stiff clutch pull, to an easy shifting bike, just by doing some catch-up maintainance on it...
Other people have changed out the multi-piece rod/ball clutch activators with simpler systems from other year XS models that used fewer parts, but try the basics first...
Thanks for all the info, i'll definitely be doing all of that. Other than an oil change, most people won't venture far into maintaining their vehicles so i definitely gotcha on the catch up maintenance. Hopefully your suggestions will clear that up. Either that or i'll have a monster hand from shifting haha
Looks like a nice start! You've got some solid advice there on your clutch, so you're in good shape.
WHen you go to clean up the clutch cable, use a siliconized Teflon. Use Tri-Flow if you can find it in a sporting goods store, rod and reel shop, or gun store. If not, Lowes sells DuPont Silicon with Teflon that comes in a spray can.
THe silicone is relatively inert, and safe on all of the plastics and cable sheath (also safe on O-rings and gaskets for if/when you need to clean and rebuild carbs) and the Teflon helps to create a lasting protection against binding and friction.
THings like WD40 or PB can some times be harmful to plastics and natural rubbers.
New cables all around - never a bad idea. They're 40 years old.
You can also get a replacement clutch worm gear unit that allows the cable to be attached further out on the arm, making it easier to pull. I have one on my XS.
My clutch was such a hard-ass I actually broke a brand new heavy clutch cable riding the bike the first few times. Not sure what all the problem was but I replaced the cable, lubed it well and put one of the replacement worm gears on and now I have a nice clutch.
Also never a bad idea to replace the multi-piece clutch rod with a single piece unit.
I have to agree with Pro- I love riding mine and wouldn't trade it for anything. The weight isn't bad, it's fairly narrow so rides like it's lighter than it really is. Great torque for around town and it holds it's own on the highway. I have MAC head pipes w/old cocktail shakers on mine and it sounds simply marvelous running through the gears. The made a bazillion of them and there's excellent parts availability and plenty of web sites and clubs supporting them.
Matt
