Throttle cable for mikuni vm30
Oldstuff315
Looking for help on how to assembly cables bought mikuni vm30 carbs 2 into 1 throttle they ends are unassmbled straight bs they couldn't assembly cables before shipping ?
It's left unassembled so that you can trim it down to size. If you're running with clip ons or clubmans, you'll need to. Make sure the 2 cable end of the cable are the same length or it'll make syncing the carbs tricky. And solder the throttle cable end after using the screw which holds it in place. Sometimes they slip out. Otherwise, enjoy the new carbs :)
Snap a pic of what you have now. Obviously the two short identical cables/housings go from the carbs to the union mechanism, which then should have a longer single cable running to the throttle.
I have a 2 into 1 cable on my VM34s so I've seen these before.
Wait till you see how "pre jetted" they are....
This is custom motorcycling, either learn the ropes or pay someone to install them.
Not looking for smart comments this is a help board if your not helping don't reply to my post thank you.
I have someone doing the jetting on the carbs for free just looking at getting the throttle cable soldered came with a bit of little tiny pieces like to know the order they go
Lol at posting on a public forum and only wanting to hear certain things....
Those pieces give you options.
What option do you need?
Ill give you a hint, it's a trick question.
Well not really a trick but not something the web can answer.
The option you need is based on the carb ends and the bar control used.
Gunna have to get off the web(nothing actually gets done on it anyway) and mix and match things for yourself. What are you afraid of?
Just try it and see what ends you need.
Hope this helps
Oh your a whole ass not just a asshole ....I have moto bars same style as original cb350 almost. Vm30 carbs cable installs on top cover take rubber nipple off unscrew etc I know about that. What fitting would suit this install frame not chopped up
Que?
Here are some pictures that helps me through the hard times
Still on the web and not trying to figure it out in the shop?
Can't wait for the "why does it run like shit?" Thread
More
More
See why you weren't at born free because your born losers ....no I am assembing bike not ready to put carbs on just yet wanted to know so when I get to that part tomm
Re: Re: Throttle cable for mikuni vm30
That comic strip is great
Well, not a picture of my firm buttocks, but a picture nonetheless. I've skipped over the last gazillion posts so I have no idea why we've got pictures of Adolf's pet bunny in here.
