Throttle/Carb issue
jro75
I am having what I believe to be a fuel delivery problem with the left cylinder on my CB 500T. From idle, when the throttle is pulled, the left cylinder does not instantly fire (so it is running on only the right cylinder). It will kick in after a few seconds of keeping the revs high. It does this each and every time from idle.
If I manually pull the throttle on just the left carb body and listen closely, it does nothing and I can hear a "pumping" type sound for a second or two and then it fires up. Any ideas what is going on here?
This is my first bike and I'm basically learning as I go so bear with me if this is something obvious.
Thanks!
I would take the carb off and so some cleaning. check the float to see that its not damaged or stuck. But first off make sure its getting gas.
really sounds like the carbs are completely out of sync... did you clean them? if so you need to sync them when you re install them, i know some people do this by eye others do it by a vacume set up...
Thanks for the replys, second one brings up a noob question though:
How are the carbs "synced" on the CB 500T? I know on the 4 cyl bikes there is one throttle cable and one fuel line going to all 4 carbs and that you make adjustments between them. However, on the CB500T there are 2 seperate fuel lines (one for each carb) and the throttle cable splits so each carb has its own cable as well. I can't find anything in my clymers manuel about syncing them other than to have the throttle levers pull at the same time (which they do) but I don't think that is what you are referring to.
Anyhow, to clarify what I mentioned earlier: if I pull the throttle lever on the right carb body it instantly revs, if I pull the throttle lever on the left carb body it makes a rapid pumping sound for a few seconds before it revs on that side.
I appreciate any ideas. I have never taken a carb apart before (this is my first bike), but I may just be popping that cherry here real soon.
that cable may be opening the carbs at diff levels... when you sync them you need to make sure they are opening the same if not you will get JUST what you are describing
Primary (low speed) is plugged, cylinder is starving for fuel....check your pilot jet for blockage and air screw settings,,don't ask mes how I know it!! ;D
