Timing Help Please 73 CL175
zcrenna
Using a homemade timing light.
I align the crank to the "F" mark per the manual, points close and the lamp lights up, but then it stays lit up for the next 180 degrees. Is that normal? I was expecting it to just connect at "F" and then disconnect immediately.
Also, the manual says to use some breaker cam lube on the points. I Don't have any of this, is it necessary to lube the points?
thanks in advance. just have to get this bad girl timed and shes 100% good to go :)
Awesome. Thanks a lot
Second question, if I tighten the cam chain tensioner and adjust the timing, do I have to check and adjust the valves?
Alright, .. So when I was working on it the other day I turned the crankshaft a few times clockwise. I heard this is wrong and I have since been turning it counter clockwise.
What I'm realizing now is that the points are in fact closing 180 degrees too soon and opening when the marker gets to F... WTF...????
No matter how much I widen the gap before it gets to F it doesn't matter because the points just start to pull away from each other at F. ( I think it's pretty understood that F is the point where the points are supposed to close)
I hope that makes sense..
Is this going to be a major fix that needs to be done? I.e. opening her up and adjusting the cam chain or something?
First up... it's not super important when the points close. It's when they open that the spark gets triggered. So what you're looking to have happen is that your light will turn on when the timing marks get to 'F' and then turn back off a little while later (again, not super important when the light goes out).
So yeah... points should definitely open at 'F'. When they close doesn't matter.
^^ What he said. Points open and plugs fire. When they close determines how long the coils saturate for and has no impact on timing.
Adjusting a cam chain changes timing but not valve clearance.
Points grease is nice. I use a drop of oil on the rubbing block or the felt. The actual points stay dry and clean - no oil where the electrical connections are made.
And just to make sure, my points connect half a turn early (half a turn before F) but then they should open (untouch) right at F ?
Correct. The light should come on exactly as the timing mark passes 'F'.
Thanks. Finished timing work, fired her up and went for a spin. Timing seems great. thanks for all your help guys!
