My stock rim on a 83 Suzuki gs450l is 90/90/19. Question is can I go 100/90/19 or 120/90/19? I know you can go a bit higher than stock but how much more?
Your stock TYRE (or TIRE, if you prefer)
is a 90x90.
The RIM is the bit that holds the tyre and is probably 1.60 or 1.85.
If its a cast wheel you can check along the spokes for size.
If it's spoked , it's stamped on the rim
The front wheel is 1.85 and the rear is 2.15. The GR650 also has a 1.85 front wheel and has a 100/90 tire on it. If you look at a tire chart, you'll see even the 100/90 is really pushing it so a 120/90 would be outright dangerous.
