m511y
Less is more
Drilling the rotor was never the plan for my CB350 project. I think they look great, but my opinion is that breaks with more surface area stop better. People will go back and forth about how drilling and slotting rotors releases the buildup of gasses and helps them perform better under extreme braking conditions. I'm not racing my bike so for me it really just comes down to looks vs. function.
Although a drilled rotor was never a part of my build plan, I am now considering it. A very nice industrial drill press has found its way in to my home and I also just happen to have a spare CB350 rotor lying around. A while back I came across this link and it gives detailed instructions on how to drill a rotor.
http://www.anubiscycle.com/cross-drilling-rotors.htm
So I'm all set to go. I have the press, bits, countersink, cutting oil, and I have mapped out my drill pattern. My issue is that the more I think about doing this the more I think it is a bad idea. I'm going to take a 40 year old cast iron rotor, drill a bunch of holes in it, install it on a wheel that will spin at high RPMs, and apply extreme force and heat repeatedly. If I do go ahead with this and the rotor cracks, it won’t end well. There will be flying shrapnel from the rotor lined right up with my torso. If the pieces of metal don’t hit me and if the front wheel doesn’t lock up, then I’m still screwed because I won’t be able to stop. The worst part is that I would have done this to myself.
I use the phrase "Just because you can, doesn’t mean you should" a lot. Is it worth putting my life at risk for a self made cool looking rotor? Or am I just being a little girl about this?
