snowdragon3
I just bought a titled '79 CB650 for $300. Non-running, the seller told me when he checked the compression he was getting between 130-145#. I've completely disassembled the bike down to the frame for a rebuild and pulled the engine out. The engine is not seized, as I can turn it at the crank shaft with a wrench. I'm not sure how he checked the compression though, because the wiring is messed up and no power getting to the ignition. Maybe he powered the starter directly.
Question is, should I do a top-end rebuild on the engine, while its out, or just try to run it as-is first? Im not sure how long its been sitting. Looks like it was laid down at one point, as the headlight assembly is broke and the right side engine covers show some abrasions.
