too many miles??
dcmspikes
Coast to Coast
is 68,000 miles too many or even realistic?? im looking at a '74 cb550. says it ran last year. anyone have two cents about this?
thanks
If it was an Airhead BMW I'd say go for it... but it's a Honda... any Hondaficionados want to chime on on how good a mill with this mileage might be?
Any engine maintained well enough should be ok. Contrary to popular belief, even BMW's can be crap if not maintained. Its not like they made the engines out of titanium or something. Aluminum is aluminum ;)
The tranny may be worn down some, especially if oil changes were infrequent. Many owners increases the likelyhood that a jackass owned it at some point.
If the rest of the bike is great and it's cheap, buy it. Rebuilding the top end isn't expensive - you can buy an entire piston/rings/gasket kit for $140 or so that is good for a 0.5mm overbore (I've done two of them). With machine shop work at $200 for boring/honing and maybe another $200 for a decent valve job, and $100 for gaskets, you're into $650 or so in parts for the entire top end rebuild.
So check compression on the engine if you can, and see if you can shift through the gears.
you see any harm in riding it until it has issues and then rebuilding? or better safe than sorry? that is just so many damn miles.
If it starts and runs I say ride it. If it's running you'll be able to spot any major issues (excessive rattling, smoking, etc) and if it shifts through the gears and runs (gotta run hard if you wanna run with me, otherwise it's time for some top end work to tigthten things up) I don't see any harm in riding it until problems pop up.
I've read about airheads going over 100K with proper maintenance, so if everything seems to be in order I see no reason not to ride it.
Well.... after fixing 2 heads on 2 different CB550's, I started to think that the 550's have a weak top end. Namely the valves/cams/rockers setup that it has. The valves are pretty skinny, the rockers are fairly flimsy, and one small problem leads to everything getting mucked up in a hurry.
I have 2 CB550's. They are great bikes, and great engines... but susceptible to catastrophic failure (bending a few valves) if abused.
Working at a bike shop, I see some old bikes come in with millions of miles on the ticker. It just depends on how it was ridden.
If it was in interstate bike, it may be normal to see an old KZ1000 with 170,000 miles on it (yes the bikes still ran like a champ).
If it is clean/cheap enough, it may be worth it! And if that motor poops out, it might be cheaper to get a used engine for $100 and just slap it in there, but.... when buying anything used, its condition is usually unknown unless tested before purchase.
Old BMWs were bought by mature, affluent riders who maintained their bikes meticulously. Old Hondas were bought by yahoos that thrashed them into the ground and left to rot. Yes, chances are old BMWs will be in better condition with equally high mileage.
thanks
Old hondas seem to go on for ever, cam chain can get rattly, and use oil as well, but it just smokes a bit and you need to keep topping up the oil, the other weak point is the cam bearings, as the cam runs on aluminium bearings ! so if the oil hasnt been changed regularly they can wear alot. My ones hads done 58,000 miles and 54,000 miles. They are easy to rebuild the top end, proof of that is, even i have done it !!!!!! and i am a bit dim ;D so i suppose as long as the rest of the bike is ok and it starts up.... sounds like an ok buy as long as its a good price. But i am bit of a soft touch for old un loved motor bikes :D ;) ;D :)
Hell, if it runs, ride it. I smoked out enough people following me on my 550F. The only reason to rebuild is to save money on oil and if you want people to ride with you!
My Honda Civic burns oil but there's no way in hell I'm rebuilding a 10 year old car engine. Oil's cheap.
I bought my cb650 with 75,000 and was wondering that same thing, but its only had 2 past owners and the last owner must of cared for it like a baby cause it was immaculate (or close enough). Runs great, shifts a little rough but thats only compared to my 250 because I've never ridden anything bigger, but maybe the tranny is a little worn.
