Top Speed Issue
MrBlue
Hi all,
I'm new to this forum and to motorcycling in general. Love the site and I've been lurking for several months. I am looking to buy my 1st bike and have my eye on a 1975 Honda CB400f Super Sport. There is a very clean one for sale in Ohio for $1250. It appears to be a good project bike. I would like to restore it to original appearance. In the ad states:
"The bike starts, runs, idles, and shifts well. It smokes a little when you first start it cold but that quickly clears up as it warms up. I cleaned the carbs and replaced any bad "O" rings. It does not leak any oil that I can see. The floor under it is dry. I have only ridden it about 12 miles since restoration. I had it up to 60 mph and it didn't seem to have much left but I was not out on an open highway. It ran smooth in all gears. It has fresh oil and filter. Exhaust has correct header pipes with after market muffler. "
I have since followed up and the owner states it tops out at 70mph. He thinks it has "too much muffler" . Muffler "looks" stock but is not. Has air intake pods as well. I know that price is pretty low, but I don't want to get hosed. What may be the cause of this top speed issue? What should I be asking seller? Could it be expensive? Thanks!!
That's like asking how long is a piece of string. CB400F is a great little bike that stock will do a ton maybe slightly more on a god day. 70 is not even close. The list of possibilities could fill a book, so let's start with the simple ones:
Piston rings not sealing
Timing off
Carbs jetted all wrong
Exhaust too restrictive
Valves not sealing
Cam timing out 1 tooth
Running on 3 cylinders
Needs new spark plugs.
Some of those could be expensive to fix but none are hard to detect. I'd start by asking him what he did to it and to show you receipts if possible. Did he have the motor apart or did he just do cosmetics? If the motor came out , who did what to whom?
$1250 seems like a reasonable starting point on pricing depending of the real condition. Do you have any pictures that we could check out?
New to motorcycling and your first bike? You don't want a "project" right now - you want a bike that is running properly so you can learn how to ride and enjoy motorcycling.
Also, you will spend more money on getting a project bike running than buying a sound machine in the first place. Seriously, we've all been there at some time.
yep 70mph is definately not right , should hit the ton and then some. always liked the 400four and would make a cracker cafe but yeah check out who did what as you can never trust anyone elses work unless they're a qualified bike mechanic and even then some can be iffy!
