Triple trees for 73 CB350
G4SJedi
Im a proud owner of a new(to me) 1973 Honda CB350G. I picked it up off a co-worker that had it stored in his garage for 23 years. Its in pretty good shape. I only paid $125Can for it.
One of the issues is the front end.The upper triple tree on both sides of the forks are snapped. It appears at some point someone over torqued the bolts and cracked the castings. What tripple tree is an exact replacement? 1973 CB350 trple tree is different than the earlier models. Could I use something from say a 74,75,76 ish CB400,500,550?
I will post pictures soon.
If it's disc brake model a CB360 one will fit, but, thy have the same problem when people over tighten the bolts (I have 2 broken ones)
I'm using a CB350 on one set of forks, was thinking about making a flat top yoke but, it will lower front end about an inch.
Not sure if CB350F would fit, I'm pretty sure I have one spare
I've fitted Suzuki forks to one bike (or at least I will when I re-build it ;D )
I got a set of Kawasaki Ninja 250 forks off e-bay, wanted some slightly smaller than the 41mm's for next bike (should be 37mm on Ninja)
I'm a noob on this. Is it a direct swap between the 350 and 360? I'm still trying to find the parts so can I just get the upper section of triple and reuse the other parts I already have?
Post a pic of what you have.
The CB360 may be slightly different where the clocks mount (can't remember)
