I have a 1972 Triumph Bonnie 650. I am trying to clean up my handlebars. I have moved to some small straight drag bars and want to remove the stock Lucas switches since they are so large and ugly. Plus they run into my tank on tight turns...not good.
I have purchased some CEV Switches from a local vintage parts dealer called DomiRacer. I have disected and ran tests on the current switches and I think I know the pattern of connectons.
Here's the rub, it appears that the Lucas switches go out of their way to not ground to the handlebars. Almost all switches that I've encountered, including these CEVs, DO ground to the handlebars.
For example, a typical horn button would simply have a single contact wire and complete the circuit when grounding to the bars. On the Bonnie, the actual physical horn has two poles, one hot and one ground. The horn switch merely is a break in the hot wire. So any switch housing that tries to ground out to the bars will not work. Add to the confusion of the positive earth configuration and I'm stuck scratching my head a bit on this. (plus, my bike is not running which is the bigger issue)
I don't really want to put the Lucas switches back on...nor is it practical with those bars...any guidance would be greatly appreciated!
Pablo
Pablo
