Triumph Handlebar Switches
pablo
I have a 1972 Triumph Bonnie 650. I am trying to clean up my handlebars. I have moved to some small straight drag bars and want to remove the stock Lucas switches since they are so large and ugly. Plus they run into my tank on tight turns...not good.
I have purchased some CEV Switches from a local vintage parts dealer called DomiRacer. I have disected and ran tests on the current switches and I think I know the pattern of connectons.
Here's the rub, it appears that the Lucas switches go out of their way to not ground to the handlebars. Almost all switches that I've encountered, including these CEVs, DO ground to the handlebars.
For example, a typical horn button would simply have a single contact wire and complete the circuit when grounding to the bars. On the Bonnie, the actual physical horn has two poles, one hot and one ground. The horn switch merely is a break in the hot wire. So any switch housing that tries to ground out to the bars will not work. Add to the confusion of the positive earth configuration and I'm stuck scratching my head a bit on this. (plus, my bike is not running which is the bigger issue)
I don't really want to put the Lucas switches back on...nor is it practical with those bars...any guidance would be greatly appreciated!
Pablo
Since this is mostly a Honda owners site I'm not sure how many Triumph experts are here. Honda electrical components do have pos and neg wires since all lights are rubber mounted and won't ground to the frame. Hondas have neg ground as opposed to the Triumphs pos ground. This shouldn't really affect simple items such as lights and horns since they work with the polarity reversed. Items such as rectifiers and regulators are polarity specific so the ground polarity would matter. Since the handlebar switches only operate the simple items, polarity shouldn't be an issue. But you will need to ground the handlebar to the rest of the bike. Most bars I've seen have rubber cushions at the clamps to dampen vibration so there would be no continuity from the bar to the frame. Try connecting a wire from the top fork clamp to a bar mount bolt with a couple of eye connectors, that will complete your ground.
I can't help much with electrical (hate the stuff) but am interested in seeing more info on the switches you bought as I'm in the market for some myself.
After spending too many hours on this, I have concluded that the previous owner did not wire this bike to the specifications. I could be wrong, but I know he did rewire and upgraded most of the front-end components. I have run various multi-meter tests and there is no way that the switch wires can be connected in the same configuration as the wiring diagram in the shop manual. This make me wonder what else I'm going to uncover. ???
I'll let you know how the switches work. Visually, they are an improvement. Personally, I like the Wipac switches instead, but I cannot source a pair of those for a reasonable price. The Wipac's look like donuts and appear to be much more streamlined. The CEVs will do the trick until I get bored. But I'd rather be riding then wrenching right now.
I didn't realize this forum was primarily for Japanese bikes...but that's okay...I have one of those also. (actually two) I am at my wits end with the CB450. I rebuilt it and got it to fire last fall. I cannot get it to turn this spring. I get a very unpredictable spark at the plug and was thinking I was chasing a grounding bug. But after a couple of hours, I have assured that everything is grounding correctly. Still I have the same problem. This bike looks really great and I thought I had carefully taken everything into careful consideration.....but this is my first total rebuild, so I guess I'm learning.
Pablo
This forum is for any bike you ride - new or old, Japanese, European, American, Bulgarian, you name it.
I'm going to Google the switches you mention but if you have any links or info let us know.
I picked up two CEV handlebar switches from a local vintage distributor called DomiRacer:
www.domiracer.com
They happend to be about 5 miles from my house and have an incredible inventory. Plus its fun to hang out there on a Saturday morning....lot of history at that place. I learn something everytime I'm there.
I spent about $20 per switch. I've seen Wipac switches appear from time to time on eBay and a few other links...usually for $50 - $75. They were more prominent on BSAs in the 60s. I don't know if Wipac is still in business or if the new ones are replicas. Most of the sites seem to be in Europe, but I've seen some in the U.S. as well.
Pablo
