Trouble with cold starts CB750
BArTY
Hey guys, I'm having some trouble in the mornings starting my bike. It's a 1975 CB750 and it's kick start only, and it literally takes about 5 solid minutes of kicking before the engine will start. I've tried slowly building compression by turning the kick start slowly before flipping the ignition and kicking to start. That doesn't work. I've also tried pulling the choke and easing it out, that doesn't work. It seems nothing works unless I just wear out my leg kicking repeatedly. Once I get it running it's got great compression and runs perfectly, I can also start it fairly easily throughout the day, unless it sits for a while. Like after work I have some trouble starting it again, but not as bad as in the mornings. I'm just wondering if any of you have ever experienced this with these bikes, (I'm new to the CB750s) and if anyone has any solutions to the problem. Does something need to be tightened, loosened, or possibly replaced? I haven't checked the spark plugs yet, but could that be the cause? Or possibly a fuel problem? Please help, my leg is getting tired of all this ???
I'm no expert, but what are your plugs showing? Could be running too lean and the choke being open may not be allowing enough fuel in. I say this because my buddy had that issue- had it set a little too lean and when the weather changed it had trouble starting up. Changed the mixture a little bit and fires up right away now
just a thought ???
just a thought ???
The plugs are brown, I don't think I'm running too lean, though I do feel as though its not getting enough fuel at start up. I will try pulling the choke at start up and see if that helps at all. Thanks for your help, I'll let you know if that does the trick. I hope it's that simple ;D
My step-dad told me once that on his old Suzuki GSX sometimes he would leave the ignition off, open the throttle all the way (choke off) and give it a kick or two. Then he would turn the bike on, open the choke and give it a swift kick. I don't know if that will work in your situation, but maybe worth a try
Ok cool, I will try that too. Thanks a TON
It needs a good service.
When everything is working properly you can start them by hand real easy.
Usually, if you open the throttle even slightly, they WON'T start from cold, has to be completely closed and choke on
So I tried what you said with some luck. I altered your instructions a bit and now I can fire up the bike in at most 3 tries. I think it all comes down to perfecting the process. I just added a little throttle twist to the last kick and it fires right up. Thanks again for your help.
I've got to agree with PJ here. There shouldn't be a trick to starting a bike if it's properly serviced. A new set of plugs may be all it takes.
Some bikes have "tricks" alright.......try starting my XT500 when you don't know what you're doing ::)
An old adage with XT owners when people ask for a ride is "if you can start it, you can ride it" ;)
The reason that it is sometimes useful to open the throttle wide is when the bike is flooded. Kicking it over with the throttle open creates so little vacuum that it basically doesn't pull in any fuel - just fresh air.
In this case the issue sounds like it's cold blooded and needs more choke for that first kick.
