T Tj_saxon New Member Dec 9, 2015 #1 Ok I am almost 100% I have got everything done to take them out? Any help or hints?
H hillsy Over 1,000 Posts Dec 9, 2015 #2 Remove the top triple clamp and the headlight ears - I'll bet you've got a metric tonne of rust on those fork uppers. Stick a flat blade screwdriver into the bottom fork clamp flange and pry it apart (gently).
T Tj_saxon New Member Dec 10, 2015 #3 Ok, I was gonna put the bolts that when in the top in a little and smack them with a rubber mallet. Is that even safe? haha.
H hillsy Over 1,000 Posts Dec 10, 2015 #4 If there's any rust at all on those forks you'll need to pry the lower clamps apart to allow the forks to slide out. Do it gently. Don't hit them with a hammer. Take off the top triple and the headlight ears and you'll see what I mean.
T Tj_saxon New Member Dec 10, 2015 #5 Yea I'm not going to any more haha. Any chance you know the size of the nut on the triple tree?
