loudest143
Insert sense of humor here---->
Well here's where I stand now. Besides missing out on a beautiful sunny day, the first of the season, The bike is still not where it should be.
122 main jet (115 stock)
needle shimmed at two washers, that's half of the stock plastic washer.
42 pilot jet (40 stock)
float height 23mm (22mm stock)
Emgo pods, V&H header and Muzzy cannister.
Carbs were bench synced again, I used the high rpm method for fuel/air mixture screw.
When cold, it starts with the choke, which it didn't before I adjusted float height. Plugs are whitish brown in color. (which is good)
Bike revs great throughout the rpm range on the stand.
As soon as I get out and ride, the bike begins to 'growl' through the carbs, and not in a good way. Power loss, and it slowly increases speed. I've been through every possible combination of jets and needle height, trying to cure this issue. So there's something I'm missing. Here are my questions for the learned panel.
Could valve shims have something to do with this power loss? They could be off. I did replace some of them prior to my carb tuning marathon. I believe they are correct, but I don't want to leave this out of the conversation. I did gap them, and replaced ones that were not up to spec. Maybe I didn't get that right. I felt good with my measurements, but it's possible, I guess.
My exhaust is pretty much straight through with a silencer. The Muzzy cannister and the V&H header combination are pretty good, IMHO. New header gaskets were installed, and all bolts were torqued to spec. Even if there was a SMALL exhaust leak, I shouldn't have this kind of power loss, IMHO.
Coils? I'm not thinking this could be an issue, but I am running Accel coils. Don't kill me because I'm cheap.
Ignition? I do have stock ignition, and maybe it's going bad? I wouldn't think this would be an issue either, or it would be failing when the bike is on the stand, too, wouldn't it?
Do I need to go up on my float height another mm? Maybe it's too much fuel....
I'd love to hear what everyone has to say about this issue. I'm really exhausted all my options at this point.
Thanks in advance.
loudest143
Thanks in advance.
loudest143
