Turbo owner calling in from the UK
Will Barber
Hello to everybody out there loving the cafe racer scene 8)
My name is Will, I live in the UK and have loved cafe racers all my biking life.
I've owned so many bikes I can't remember them all... Here's just a few in no particular order: Yamaha FS1E, RD250, Suzuki GT750, GSX550, GSX1100 (x2), Kawasaki Z500, H1B 500, S3 400, KZ1100 ELR, ZRX1100C4, Honda SS50, C50, C70, C90, CD175, CB250NA, CB400NC, VF500F2F, Malaguti Cavelcone 50, Moto-Martin KZ1100, S+S Silver Saxon Turbo.
Suzuki GSX1100ET
The KZ1100 ELR I finished building just a few months ago...
Yes the last 2 bikes listed there are full-on cafe racers.
This 1983 Moto-Martin KZ1100 I owned from 1987 to 1994.
This is my current 'Ultimate' cafe racer, a 1979 S+S Performance Silver Saxon Turbo.
Off out now to a Christmas party so back soon with more pics and chat.
Will
[quote
[/quote]
I got wood! I got wood!
I've owned this for 8 years now. It used to belong to the heavy metal rock band "Saxon" who used to ride it on and off stage on their "Strong Arm Of The Law" tour back in 1980.
This is the lead singer Biff Byford and bass player Steve "Dobby" Dawson with the bike at the 1979 Earls Court show just after buying the bike from S+S Performance.
It had been messed about with when I found it but fortunately all the standard gear was still with it.
This was it how I found it, still unregistered and with only 800 miles on the clock!
It's not been easy getting it to run trouble free free whilst delivering a reasonable amount of turbo boost though.
I've blown two complete sets of pistons over the course!
Trying to get forged flat top turbo pistons today is extremely difficult. I had to wait three months for this set of 74mm pistons to be made by MTC.
Back then in 1976 when this prototype bike was being built, it was still running points & condensers.
Nowadays is runs Dyna 2000 with boost activated retard function, with the 8 degrees of retard called in at 4 psi and boost blow-off at a moderate 6 psi. This still gives me around 170 bhp at the rear wheel.
Last year I was running it at 10 psi blow-off with just over 210 bhp at the rear wheel, but due to the wategate being completely mechanical, it's easy to go over that blow-off, and last year the wastegate completely failed to open at all whilst under maximum boost and ended up shoving 65 psi into the cylinders! The result being four sandwiched pistons so that's why I run a lower blow-off now. I've also changed the rate of the wastegate spring for a 40lb spring instead of the standard 80lb spring so it won't happen again (hopefully)!
The crankshaft is a fully welded and balanced Russ Collins item, it runs heavy duty crankcase and cylinder studs, piano wired liners, a ported & flowed S+S head with S+S cams, Dyna coils, MTC leads, a centrifugal MTC lock-up clutch and Mikuni HSR flat slide pumper carb.
I ride it as often as I can and often go to the Classic TT races on it too, where it does gain a fair amount of intrest :)
Regards, Will
