turn key and start?
7aliveatlast7
the bearded hessian
so i have your typical turn the key on and press the start button kind of ignition. however, i recently saw an old kz440 just like mine with an ignition similar to a car, where you turn the key to start the bike, no starter button required. anyone here done anything like that? i'm guessing a wire in the starter button control has to go to the ignition instead, but i'm a total noob when it comes to electrical stuff, so i'm wondering if it's a hard thing to pull off. how would i do it? thanks in advance for any tips!
You can get a key start ignition at any auto parts store. When you turn the key all the way to the end, the starter circuit is completed for as long as you hold it there. Should be straight forward to figure out which wires to connect.
Check out Marine switches too. They are frequently designed to be exposed to the elements in ways that a lot of automotive switches aren't.
+1 to this ^^^^ Usually a few more bucks but worth it for sure.
Keep in mind some relay work may be needed. Many bikes have the headlight circuit tied to the start switch, so the headlight goes off, allowing more voltage for a start. It is a good idea to keep that feature.
If done correctly, I believe that is the same with this type of ignition, (like why your radio skips a beat when you turn your car over) but I may be wrong, worst case, do what most people do and have a headlight switch.
my headlight actually comes on when i turn the key to the "on" position, even before i hit the starter button. so is that one potential problem out of the way, haha? have any of you ever done this mod on your bike(s)?
not sure why you want a car ignition switch but...............
there are several year kz440's and diagrams but i believe they have a two wire start switch so your turn to start switch will have to connect the two wires electrically to start the machine....if you eliminate the stock throttle assembly you could jump the kill button(off/run) or mount a remote one somewhere else if you need to have it.
or you could buy an vintage moto guzzi v7 which had the car start switch on some models.....
joe@ vcycle
www.joesvcycle.net
