turn signals wont blink
brewtown16
what, me worry?
74' Honda CB360G
they stopped working when i had to cut and re wire the (white) wire that was corroded near the switch when i was putting on the bars.... notably, the jackass owner before me cut all the wires at the switches instead of d/c them at the harness near the battery. i had to re-solder all the wires. well, the lead in was two white wires, but there was only one white wire going into the housing and switch... so i laced up the three together. well.... whats even stranger is that the bolt for the housing got lost so i used a slightly longer one made of brass that i found in my garage. it goes too far and blocks the switch in the off position. so i went into my garage and found a bolt that would be short enough, and secure down the housing.... they actually worked!....for like 10 seconds then like some kind of magic the damn thing burns the rear tail fuse, 3 times.... i switch out the bolt and havent had a problem. NOW, yesterday, i unscrew the longer bolt a little, just so the switch can slide, but they stay solid, no fuse burning....(turn signal relay fried?) ill take some pics when i get back from work around 3pm, and ill also photo the wiring diagram from my clymer manual.... all i can say is ive rewired Volkswagens, t buckets, and a CL450, and ive never been more frustrated or dumbfounded in my life.....
I can only say you will have to recheck everything step by step,
you may have to remove or unplug the componets from the main harness to check
the flasher relay works,
all bulbs work,
turn signals assemblies work
good grounds
clean connections
continuty check
then go through the wireharness and trace / continuty check ,
Hope this helps,
I am sure it doesn't
hammy
I think you need some of this:
:D Sorry but I couldn't resist.
brewtown16 said:
how did i know you were going to do that...
lol, you probly saw the topic and giggled like a little girl
LOL, yup, pretty much.
Did you get the wiring straightened away yet?
took a weekend of fab'ing and fixing stuff. ill take some photos in the morning of the wiring and of all the new work.
Useful Idiot said:
I've found that 90% of the time it's a bad ground or a bum flasher relay.
+1 after deciding to stick with the stock signal lights i had one that wouldnt even light up (right rear) so i fig'd it was the bulb....opened it up and saw the bare ground wire broken from the eyelet held by a screw.....put a new eyelet on and the blinkers work fine now. now all i have to do is figure out what type of tail light i want.
