Turning Drum Brakes?
woody1981
Coast to Coast
DTT BOTM WINNER
Hey guys. Question of the week here... On the front drum hub for my 450 there is some rust/corrosion inside braking surface. Is this something I should be worried about? Can the hubs be turned or skimmed? I have the wheels dissembled right now so they are pretty easy to work on. Thoughts? My only concern is that the inner surface looks like it might eat new shoes.
Also, I am having some trouble locating front brake shoes? Anybody have a good source for CB450 FRONT shoes... rears don't seem to be as hard to come by.
Thanks,
Woody
There's not enough lining there to machine. I used a drill with a sanding cylinder to get rid of the corrosion. Or you can use emery cloth. As you use the brake the lining will be smoothed out by the brake shoes. Vesrah still makes shoes for front brakes. Any bike shop should be able to order them. Or there's always ebay.
They also make hones for brake drums. I was always told to have a perfectly cylindrical drum, or your brakes won't work right.
If they aren't perfectly cylindrical, you may want to consider bringing your wheel to a shop.
I don't think there is much issue with them being cylindrical... but thats not exactly something I can eyeball. There just seems to be a bunch of corrosion from sitting. Can they hone just a hub shell with no spokes, rim, bearings etc...? Does a cycle shop do the honing or do I need to take it to an auto brake shop?
I think I am going to try the sanding drum trick first and see how it looks.
- Woody
Yes they can hone the wheel without dis-assembling it.
Sounds like a good idea, but be careful or you may make it non-cylindrical.
No... my question is can they hone it when IT IS completely dissembled? Cause that's how it is right now... completely taken apart.
Also, should a motorcycle shop be able to do this?
-Woody
-Woody
Yes then can do it. I'd take it to a machine shop that specializes in stuff like boring out engines.
Don't waste your time to have it Honed!! give me a friggin break! hand sand it and if can't afford racing linings,have your brake guy rivet fork lift linings to the shoes!!,,,,,,,,,4 seasons of racing .........and 10 times better than vesrah
Buzz, the big issue as i see it is that we're all working with bikes that have been majorly abused. When I see a drum brake that has rot inside of it, you can almost guarantee that it's not going to be circular. A brake drum that isn't circular is not only ugly, but outright dangerous. If you ride it as it is, you may wear it down to circular again, but you'll get uneven heat in the hub, which can warp a wheel or crack a hub in half ... while riding it. Riveting a race lining is a good idea if the drum is circular. if it isn't, then all you're doing is compounding the issue.
Safety first!
depending on the level of corrosion(extreme pitting) find another hub!if its rusted and they usually are! sand it.So you want it skimmed,dismantle the wheel,jig up between centre's on your lathe and turn it. I have 350 front hubs with no more than surface rust,and when cleaned they will work fine!! as for your replacement shoes Thilbault imports #013-101(67-71,k1-k4)..#013-102,,72-74,K5-K7,,,,,,,,GOOD LUCK
