Turning out some pretty sick powder workt his week!
clear on the polished sections
done
Is there anything I canuse to smooth out metal before sending for powder ? I know you cant use bondo but can you use something like allmetal ? Thanks
really depends on what you are fixing and how bad it is. We have brazed, welded, filled, and primer and blocked to fix metal. on tins we will pull the dents and smooth them out... there are several pics on here of tins we have done, if you have any questions or can not find them let me know, i can post pics. we specialize in metal fab here in the shop as well as coating so we do a ton of pretty crazy repairs.
Small pits and corrosion can usually be covered with a self-leveling primer (I'm sure these guys are familiar with it... it's some crazy wizard shit the way it fills in!)
I've used high-temp JB Weld on very small dents without a problem but you've really got to have a good surface to bite first. (rough it up with an abrasive disc)
The best is of course to braze or weld to fill in if you can. A shop willing to do light fab work to fix it for you is well worth the cost if you don't have the skills.
-Deek
we also do dent repair and crack welding on wheels here in the shop, we where able to save these dyna mags for a customer
little reminder of what the wheel looked like before
What I have is a front fender I cut the ends off and welded back on ( shortened the fender ) Got pretty much smoothed out with welding and grinding but could use a little filler . An English wheel would probably straighten it out but I don't have access to one . Thanks
ah stuff like that we just body work out... the fender shown above had some good grinds/dents in it prior to coating, smoooth as glass now
no bondo will not come close to holding up... some guys use JB weld however I find that it shrinks when heated and leaves an outline that can been seen tough the powder... not a fan, it hink metal lab is better but to me both are not really options in the shop. we will metal work vs using a filler anyday.
