Turnsignal indicator
jmkk
Hi,
I just installed a new speedo with idiotlights.
Everything works fine except for the turnsignal indicator. My original speedo (Honda CB450s '88) has a left and right indicator (each indicator has 2 wires), and the new one only one, which says if it's blinking, and also has 2 wires. (see attachment for old and new speedo)
So I've got 4 wires which need to be connected to 2 wires.
What I tried, with my noobish electrical skills, is put the wires of left (+) and right (+) together and connected them to the +wire of the new led. (-) is connected to (-). When this is done, the left and right turnsignals blink simultaneously because the electrical signal is flowing through both.
How do I fix this?
Please help
Jim
Amsterdam
JMKK
You need to install a set of diodes to block the signal from opposing turn signals for the idiot light to work. Here's the diode you need from Radio Shack:
http://www.radioshack.com/product/index.jsp?productId=2036268
Or you can buy a kit:
http://www.cruisercustomizing.com/kuryakyn-diode-kit-for-metric-bikes-each/part/KY-4709
A diode is a "one way" switch that blocks voltage from traveling backwards. It will allow your turn signals to use the "2 wire" setup.
See page 21 on my project listed below.
Alternatively, you could use a flasher relay with a "pilot" output, and run a single wire from it to the dash. The pilot out is basically a separate circuit for the dash indicator, but will flash at the same rate as the signals.
