AzHonda
Coast to Coast
Have a couple of questions.....
Iam putting VM30's on my cb360 and have the universal two into one throttle cable. My first question is what would be the best surefire way to go about cutting to the proper length? Would I measure end to end on the existing cables? Seems to me that that way wouldn't work due to the cables will actually be going into the carbs.
My thought is to hook up each end into each carb and then run the cable up to the throttle and make my cut there? I would treat it as if the throttle is closed right?
Other question is the throttle itself. Right now I have a new push/pull one from DCC. What type of throttle would I need or would this still work? Seems I would still have an opening on the "pull" side though? Also, shouldn't i have some sort of housing that hooks up to the throttle like on the push/pull?
By the way, it's the universal 2 into 1 throttle from DCC.
Thanks for any help.
