TX500 Newbie
Well I was checking the rubbers yesterday and it seems like there are a few cracks light dry rot cracks on a tire when you bend it, but nothing huge and visibly going through the whole mount.
spray carb cleaner around the boots if there is a leak you will hear it in the idol of the bike when you find the leak...
So I got to finally work on the bike today. Got the pdf manual off here and looked at the timing. OMFG it runs so much better now, even sounds a ton better. Also the idle doesnt jump up to 4500 anymore. Timing was off and gapped the points. Took it out and top speed was 50mph. Came back and did a quick cleaning of the carb jets, bowls, needle, all the little holes took it back out and still only 50mph top speed.
So next chance I get I am going to change the plugs, wires, and check the valves. Any ideas why it tops out at 50?
Its hard to describe. Its max rpm under load is about 5k. W/ out load it will rev fine. Ill shift to 5th and get to about 4-5k rpm and the more i twist the throttle you can hear the throttle get a deeper tone like its sucking in more air but the engine makes a chattering type of sound if that makes any since.
It sounds similar to my civic when i was having ignition problems where at a certain RPM it had no go. But I could get my civic up to highway speeds
Well ive been out of town the past few weeks. Im home for the weekend but things come up and I never get around to it. I am hoping to take off monday and have a long weekend to tinker with it. We shall see.
The first bike I ever owned was a tx just like that! It was free and completely roached though. I never put it on the road, but I've always had a soft spot. Good luck with her dude.
That is a fun bike, I can say. I'll share pics of the one I had.
Did I read correctly that you don't have the factory airbox on there? If it has pods, or something else not original, and you're still running the original jets, that could account for the lack of power. My airbox was shot, so I ran pods, and THEN found out that you can't get jets for these carbs. I had a friend with a machine shop bore out the jets ever so slightly, did a plug chop, bore them out a touch more, plug chop, etc. until I got them spot on, and the thing ran like crazy! They're not the best carbs out there by a long shot, but I still managed plenty of power.
I still miss that bike, it was a looker, and I had plenty of fun on it.
Well ive replaced the condensor and plugs and I just need to play with the timing and I think it will be good to go. Right not it has problems going up hills and at WOT it just sits around 5k rpm so a little playing with the timing and i think Ill be good to go.
Now my next step is to either do a head swap or just swap out the entire motor from a 76+ XS500. Mine is leaking oil everywhere and I just hate having oil on everything you touch besides making it look bad.
Problem is finding a motor that someone won't charge you an arm and a leg and they don't even know if it runs. Ah the love for the bastard bike.
