Pardee
To start from the beginning, and to keep a long story short, I inherited a '73 TX750.
As most know, a TX750 is definitely not a desirable bike.
This bike sat for approximately 20 years in a barn and needed some TLC.
After getting the bike home, it needed more than a little cleaning.
My first goal was to get the bike running, a dead bike is a dead bike.
After rebuilding the carbs, installing a new battery, plugs, and a few minor parts, it fired and ran pretty good.
When my budget build was about 80-90% done, I noticed the one-way starter bearing / mechanism started acting up.
I was familiar with the concept as I had to replace one on a new ATV that I previously owned.
I knew the starter was good, and was able to count that out.
I pulled the flywheel and noticed the springs were stuck and the mechanism was not working properly.
I purchased a rebuild kit for the one way mechanism, and cleaned / installed the new springs / dowels.
Unfortunately, things started going down-hill from here.
I installed the flywheel / chain / gears without any problems.
I referred to the Service Manual when setting points and timing.
I was able to get the bike to fire again, but something was not right.
After shutting the bike down and attempting to fire it back up, I checked the timing and noticed the points and flywheel markings were not correct.
I could reset the marks and get the bike to fire, but after every running attempt, I would have to manually set the points. The only way I was able to get the points back in line was to pull the clutch basket and manually turn the gear / shaft for the points to ensure they were opening at the correct time. They seem to be jumping.
I am not sure if the woodruf key is worn, as it was not when installed.
This is where I have let the bike sit.
I have not touched any other internals of the engine itself.
The bike has approx 5K original miles and has not been modified.
Any suggestions would be great.
I'm not afraid to dig into the internals, but would rather learn from those who know from experience.
Thanks in advance.
Thanks in advance.
