Too many bikes, too many projects, not enough space or money. Fire sale at Tim's place! Located in Toronto but will haul to the right buyer.
Build thread spanning the first 5 years of DTT history - http://www.dotheton.com/forum/index.php?topic=448
1972 XS650 frame, 1980 or so motor. Nothing is stock.
- 1972 frame de-tabbed, center stand removed and bracing added to stiffen frame and reduce weight - Ontario title
- 750cc forged piston big bore kit with larger cooling fins on cylinder block
- Kickstart-only - electric starter motor and internal gears binned to save weight
- Crank and cam rephased to 277 degrees to improve torque and smooth out engine vibrations
- Pamco 277 degree electronic ignition
- Ported and polished head by 707 Racing with enlarged titanium valves, springs and retainers sourced from a NASCAR engine and custom short valve guides for increased valve lift
- Shell #1 performance cam grind
- Taller 5th gear for higher top end speed/lower RPM
- Mikuni VM34 carbs
- DWMS breather catch-can/filter
- Brituro Megaton racing megaphones
- Tomaselli adjustable clip-on handlebars
- Tomaselli SuperPractic B throttle
- RAM rear suspension (aluminum bodied properly sprung top of the line suspension out of the UK)
- Race Tech Gold Valve cartridge emulators and springs up front - the real deal set up by our own Beatnik - a motorcycle suspension professional
- Suzuki 4LS GT750 front brake - perhaps 1000 miles on new brake pads, new cables
- 35mm forks - tree has been modified to fit early XS frame with shorter steering tube. Would bolt onto later frames with a stock triple tree no problem.
- Custom 6 gallon Norton Manx replica tank - hand built by Evan Wilcox - look him up
- Clubman Racing Norton Manx replica seat
- Stock 18 inch Yamaha shouldered alloy rims laced with Buchanan stainless spokes - 18 inches front and rear
- AVON RoadRider tires
You get the idea.
Asking $4,500 Canadian. US buyers do the math - US$3500 or maybe even less. The Suzuki 4LS front end on the bike is worth a big chunk of this, as is the aluminum tank. Re-phasing an XS650 engine is not cheap, nor is a 750cc big bore kit. This bike has it all.
https://www.youtube.com/watch?v=wSIHUG5DyLw
- Mikuni VM34 carbs
You get the idea.
. Nice bike.
