Unclog CB350 gas tank
72texas350
What is the best way to unclog the small tubes that come off the back of my gas tank. The tubes where a fuel line runs between them from one side of the tank to the other. They are clogged with tank liner.
Very carefully heat them to red hot and bend them straight. Use a small drill bit and electric drill to VERY CAREFULLY clean the liner out. Reheat the tubes and slowly bend them back into place.
Is there anyway to do it without bending the tube? I don't have anything with my at the place I'm staying for the summer to heat it enough
Take a piece of old steel cable, fray one end, attach to drill and snake it through the tube. Works like a charm.
Seems like a neat little trick, I'm going to have to remember that, however after the last time I stabbed old frayed steel cable into the palm of my hand I'm a little scared of it haha.
Worked perfectly! Thanks so much!.
I was a little afraid of that too. I used a drill bit to go in as far as I could, and then I put the cable in as far as I could before starting to spin it with the drill. I also didnt really fray the cable that much before I put it in the tank, I just spun it counter clockwise for a second with the drill to let it fray itself before I spun it clockwise to start digging out the tank liner.
