Universal Seat Hoop Kit $40 SHIPPED TO THE LOWER 48
Hurco550
Keep er' Between the Ditches
DTT SUPPORTER
DTT BOTM WINNER
Greeting to all my fellow bike enthusiasts.
I have been working on a side project for an affordable and universal seat hoop kit that will not break the bank. I have to be honest that I am following SONIC's vision, to give an affordable option for a seat hoop to the average Joe that may not have access to a tubing bender. It seems that Sonic has been out of the business for a bit, and I'm looking to fill the void.
What you will receive for $40 shipped to your door (in the lower 48) is everything you need to fabricate a tail hoop to the specifications needed for your specific bike. I’ve tried to design this in a way that it is more useful to a broader range of bikes and models. This kit is more flexible, but because of that, there will be a little more work required on your end. You will receive four (four) pieces of bent tubing in which to construct your hoop, as well as 5 weld in brace/alignment tubes to aid in assembly and mounting to your bike.
With this kit YOU WILL NEED TO TRIM, FIT AND WELD the hoop at the joints to fit your specific need. This tubing can be cut with a hacksaw or a cut off wheel on an angle grinder, no need for any fancy equipment. There is purposefully extra tubing on either side of the bends to ensure that you have enough material for the job.
Here is an example of a hoop that can be made from this kit. the overall length of this specific hoop is 14" and outside to outside width is 8 1/8". These can be made to be up to 12" wide with the kit provided and the "legs" (from the end to the bends) are roughly 9".
You will have your choice of upswept angle. The one shown above is 30 degrees. I will make 0 deg. 10 deg. 20 deg. and 30 deg. but I can also do custom bends if you have something specific you need outside of those "standard" ones.
The material is 1" o.d. .120" wall D.O.M. tubing, and all bends are done on a 3" centerline radius. This means that the rear "hoop" would have a 7" outside diameter if it is cut and fit to be continuous. if you want it wider than 7", there will be a straight spot in the middle of the hoop.
Once cut, fit and chamfered, the components can then be welded together and sanded smooth.
I am planning on making around 15 sets in the first run. Please p.m. me here if you would like to order, and include your desired upswept angle and I will get back to you on details. I will do my best to keep up with orders in a timely manner, but please be patient as I am doing this on the side on top of a full time job. The first shipment of tubing should be in the coming Monday (1/9/17) and I will start making kits at that point.
If you do have an "oopsie" and make a cut too close, or otherwise scrap a piece, each spare component will be available at $12.50 a piece shipped.
Thanks for Looking!
Material is in. I can knock off the $7 shipping and take them to the garage brewed show in Cincinnati the 28th if you order in the next few days.
