Using brakes blows the main fuse...
JBeck
I'm having a weird problem with my KZ305 cafe project... I'll go through it from the beginning for you guys.
Starting out, I replaced the turn signals and taillight and speedo, and kept the stock headlight. After doing all that I discovered that when I use either brake, all the lights would dim and then the main fuse would blow. Not the taillight fuse...
I eventually got frustrated with figuring it out, and decided on re-wiring. The only things I kept were the headlight, taillight, speedo, regulator and electric start (no kick, unfortunately). Turned the key, everything comes alive! Except that the taillight was dim, and using the brakes did nothing (the light didn't get brighter, and the fuse didn't blow), and the relay for the electric start would click, but the motor wouldn't turn. During my re-wire, I decided to use a circular distribution block for the grounds. I found that the ground wire from the engine wasn't connected to anything (oops), so I hooked it up to the block. When I turned the bike back on the taillight was considerably brighter, and the starter would turn over, but I have the same exact brake problem again.
I'm totally stumped on this, with no idea how to move forward... I messed with it a bit today, taking the engine ground on and off to see what would happen. When it's not connected, the speedo and headlight are brighter than the taillight and the brakes don't affect the tallight. When it is, the brightness of the lights is opposite and the brakes dim all the lights, and blow the main fuse...
Sorry for the long-winded first post.
Any help is appreciated, thanks!
Disconnect the tail light from the harness and then use your multimeter to measure resistance from the brake wire to ground. You should not get a reading.
Disconnected the taillight, checked both front and back brake wires, and the meter jumps when I use the brakes. Connected straight from brake wire to meter to ground, made sure nothing touched the frame. No reading until I use the brakes...
Bad brake switch, sounds like. Disconnect the front and the rear and test separately to find the one that's the problem.
So I tested more today. I disconnected the switches entire from the harness, one by one to see if they still had the problem when connected to ground. Neither would do anything when entirely disconnected. There's a blue wire and a brown wire coming off both switches, the blue wires go back to the taillight, and the brown wires connect up with brown wires from the ignition switch, and right-side handlebar switch (kill-switch, and starter button) as per the wiring diagram. I decided to disconnect the other brown wires one by one and see which would make the problem stop. Luckily the first wire I disconnected made the problem stop, but I tried the others just in case. The wire that stopped it came from the right-side HB switch, so I thought maybe the switch was shorting on the handlebars. Took the switch off the handlebars, tried again, still have the problem...
My guess is that you are grounding out on a wire between the switch and the brake.
Riding home one night I noticed that every time I hit the brakes my lights went out.
Turns out that the seat was pinching the + wire going to the brake light, so every time the brake switch put power to the brake light the + grounded out killing my lights.
Alright, I hope this works.
I tried my best to take the stock diagram, and slim it down to what I have now, and change any connections I made.
