Can anyone guide me how to make sure the Valve adjusters are set to spec? I want to check on this to make sure they are positioned correctly. Here's my current state. I have a pamco ignition in there.
Been years since I had a 350 but the key thing is to set the motor to TDC and check that teh valves are closed. The slotted shafts are eccentric rocker shafts. Loosen the locknut and rotate the shaft as required to get the correct gap between rocker tip and valve stem.
