remijens1
Hey People!
Im from Norway and New here. i will try my best to Express my self in a way you understand.
Im New into cafe racers but love my bike more then all the other bikes i had all togheter. its just pure pleasure driveing this time machines
Im currently working on valve adjustment on my cb450 74 k5. Step 10 clymer says:
Next, rotate the generator rotor 360° counterclockwise to bring the right hand piston to the top dead center of the compression stroke and then check both the right inlet and exhaust valve tappet clearances in the same manner as for the left hand side.
But all the post on internett says turn it 180?? what should i do?
My bike did run well last summer, but when the Cold came it suddenly cut off in the mid range at right cylinder. I change spark plugs and it runs well for 3 min and back to cut off again.
Today ive did the cam Chain and now i try to understand the valves.
i also have a question aboute this: (Table 7 – Valve clearance adjustment) specifies the correct turning direction. Note that the shaft need to be turned as shown in (figure 26 – Adjusting range turning position...
Can i only turn the srews one way? and if i did turn it more than half a turn what will happen? Im afraid i have really fuc.... Things up With the valves today.
Any help will be deeply apprechiated.
Thanks and have a Nice day, guys!
