Velocity Stacks.
Curbcast
Over 1,000 Posts
I have a stock cb200. Getting CL pipes & was wondering on first off where I can get stacks. & 2nd if theyll do me any good. Since Im new to engines Im basing my bike ideas on looks, cause its easy to know what looks good.
Velocity stacks. Where/What/How/Why?
I just wiki'd the stack thing, & its to smooth the air. So its basically just high flow without a filter. Ive seen on here to makeshift a filter to slip inside. Good idea?
Any tips would be great.
Thanks
they're not as much for smoothing the air as to resonate with the intake valve, so length and shape has an effect on what rpm range they will come on, and where they will detract from performance. if you're going for looks, then it won't make much difference really... but i'd probably go with filtered ones
So theres a science to it obviously. With the little knowledge I have is it worth messing with them? I figure if I mock up a filter inside em itll just be like a pod anyways? Thanks. Where can I get a set?
funny, i was just scouring the net for material on how to design intake trumpets properly, but came up short.
can anyone recommend either some cad software or books on intake design? shit, I'll take mathematical formulae...
I'm almost starting to think trumpets may be a 'snake oil' idea after all... if not for the fact mazda did amazing work with variable length intake runners and the FIA banned the use of them in F1 :/
I figure there's got to be a series of equations someone's pieced together using airflow volume, base diametre, trumpet inlet diametre and lip radius...
Some years ago, a fairly prodigal friend of mine was in charge of intake design for a formula SAE team, and i remember him binning 15+ sets (that's 60 individual aluminium and carbon fibre handmade trumpets... sigh) of runners because they "weren't quite right". Might be worth my while giving him a call.
sidenote: Most "supercars" (australian version of nascar, basically) used 7/16" radius for the bellmouth lip, as did renault for F1, but then those scenarios don't necessary translate...
edit: seems i've answered my own question - this site has some rudimentary calculators, but being borne of the internets, i've no idea how much credibility to afford it: http://www.rbracing-rsr.com/runnertorquecalc.html
