VM34 Tuning Help
djg42
Hello,
Any help would be greatly appreciated!
I am in the proccess of tuning Vm34s on my 1980 Suzuki GS450.
Slide-2.5
P6-Needle Jet, 6DH4 Needle
-I started out with the richest pilot I have #35, Needle second to bottom, Main jet 200.
The pilot was way too rich, idled pritty good with the mixture screw 3 turns out. When Cold, it was totally balls up to 1/2 throttle, which is really what I want. When warm it started to bog.
-I Put in a 30 Pilot Jet which was still to rich, 25 is about right for the idle, but its to lean and cuts out with any throttle with the 25 with the needle in the middle position.
My issue is, I need the needle set rich or a rich pilot jet ( at second to the bottom) for the bottom end to perform, but then I get a momentary huge bog right at 3/4 throttle, once Im past 3/4, and up to WOT its crisp and awsome.
-If I raise the needle, to second to the top, its crisp 1/2 to WOT, with no bog at 3/4.
BUT the low end is then lean, and 0-1/2 throttle lacks power.
So right now its seems I need a really rich pilot or rich needle setting for the low end, but I need lean needle setting for the top end.
I guess my question is, where should I go from here?
Try a a richer slide (size 2?) or find a different needle?
Thansk for any help, and sorry if this doesnt make any sense, my head is spinning
I may (and usually am) wrong, but VM34s are pretty effin' big for a 450. I dont know much about that bike in particular though...
Thanks for your input. I wish I would have got the Vm32's,i mistakingly thought 34s would be good because there the same size as the stock carbs. Unfortnatly, people are usually only looking to trade for smaller VMs and not 34+'s. Im gonna try to make these work, and if need be switch later(at least Ill have some good experience then)
Ill be honest, carbs arent my strong suit. But, tuning 34mm VMs to work with your bike may be banging your head off the wall to cure your headache. Im sure someone who can explain the whole thing in much greater detail that I will pipe up soon.
All I can offer is what I have on my GR650 (also with vm34's):
2.5 slide
195 mains
25 pilot
6F9 needle
P6 needle jet
mixture screws 1 turn out
Granted, it's 200cc's larger, but I'm running an OEM paper air filter too. While my filter is restricting the flow more than yours, there's only so much fuel that can fit in you combustion chamber. So a little bit leaner all around may work better for you.
One thing though: I'm still experimenting with my idle/ pilot system. So those numbers will change for me.......
Thanks rich!
All I have is velocity stacks with a steel mesh screen, and fairly open exhaust. From fiddling around, I have gotten most of the different throttle positions to perform well(at different times), so Im hoping I can Make the VM34's work, otherwise Ill go ahead and put the Vm34s up for sale and order some 32s.Thery not to expensive atleast.
I am trying to tune the carbs from bottom up, but I have 200 MJ in, and WOT is totally awsome. Granted, I never really ride like that, but I know atleast WOT that these carbs suit the bike well.
For 3/4 throttle to run well, I need the needle 2nd to top notch, but then the lower end seems lean. I have the sudco manual(which is mostyl a catolgue) and it says this kind of diifference issue between the low+high end might be corrected with a richer slide. Im thinking ill order a #2 slide, and see how that is. If that doesnt make things clearer, ill go for the 32s, lord knows i cant help but to spend time and money on this bike!
Thanks again rich for your advice, its always incredibly useful. After seeing your bike on here, Im constantly looking online for a GR650 project,totally fucking sweet. I didnt even know Suzuki made a 650 twin. For my next bike I for definitly want a 650 twin, or a 500 single(my brother has a SR500, which is awsome). I loved my tr6 and BSA A65, i think 650 twins are where its at.
I'll tell you what, when I got my 34's, they were jetted WAY too rich. If you'd like, I can mail you all the old parts (slides, needles, etc) if you want. I do need to check and see exactly what they are though.........
Thanks rich!
I think maybe our VM34s might have came the same, I had to get a leaner on the Needle jet right off the bat. They came with 260MJ, 2.5 slide, 6DH4 needle, and Q2 NJ, which made the entire mid-range rich even at the top needle clip, regardless of the MJ.
I then got P6s NJs which cured themid range richness. Maybe ill try a even leaner NJ,P4? Then maybe I could go to a lower needle clip position to satisfy the lower end, with out getting the 3/4 bog.
When I first started, I had 35pj in at the second to bottom needle clip, and it was so awsome before it warmed up, so Im thinking some how I can tune these right. I just wondering if I should try a a richer slide or NJ?
Ok, I can't add anything helpful, but I want to see how you go.
Carb upgrades to go with the K&N's and my pipe are definitely hovering in the back of my mind on the odd occassion, so I'm keen to see how you go with the VM's.
However, so far, I'm thinking if I do something I might be better off going VM32's going by what you've found...
Hey Pete!
I still might get Vm32s and sell mine. Right now I have it running well on all throttle positions, but I need to have the needle on the second to top, which makes around 1/4 throttle a little lean. Im going to order a leaner Needle Jet, so I can drop the needle clip a position with out getting the bog at 3/4. This way im hoping I can get the low end grunt back I lost from raising the needle. I have a P6NJ now, should I get a P5 or P4?
Think of it this way, a change in N/J diameter has a large effect at smaller throttle openings and progressively less of a change as the needle rises. By that I mean that it's the same absolute change in flow but a changing percentage. A change might be say 230% more rich with the throttle almost closed to say 10% change at WOT because it's the relative change in annular area that counts.
I use a spreadsheet to work out needle and needle jet cross sectional areas at different points and for there it's easy to run a second set of numbers for a different part to compare teh change in annular area as a percentage change over the baseline.
You could also look at alternate needles to grab one that has a thicker or thinner root diameter and different taper.
Thanks alot, great info. In making changes to the NJ, i sone size up or down a big change, or should I go two?
changing from Q-2 to P-6 with that needle is a 16% reduction at small throttle openings, dropping to a 3% change at WOT.
As I understand your symptoms, it is lean just off idle with #25 pilot and P-6 with needle in highest clip position. That suggests you need a P-6 NJ with a needle that's lightly thinner at the top (slight opening) and thicker at the top to lean out the top end. You have a few options, but 6F9 is a good place to start. It has a single taper versus the double taper on current needle, so it might go rich at 50% open and then clean up again. If that's the case. try a 6DH3 which is even leaner at the top end.
I just double checked a pile of needle jets. Sudco list the 176 as fitting the same carbs as a 159 series and they are correct. #175 has a thinner top flange and would sit slightly low in the carb bore. 176 would do the job (now replaced with #270 series according to SUDCO).
176 on left 159 on right. 176 is 1mm shorter but that's not an issue
I ended up Using a HD2 needle with P8 Needle jet. This helped alot, Its pritty balls out now, iwas surprised at first when the front tire popped up a bit with throttle-but Theres a small flat spot right off idle. Its better when I raise the needle, Im pritty sure my slide is lean. I really don't want to spend $50 on two new slides.
Anyone ever file there slides down? any instructions/advice would be awsome.
How much should I take off to mimic changing from 2.5 to 2.0 slide?
Thanks!
That would be 0.5mm IIRC. That's a bit of a cheat in that the cutaway should be at an angle, but I suspect you can trim 20 thou off the floor of the slide without it hanging up. Last one I did with an angle grinder at the race track to clean up bottom end jetting. I never did get around to cleaning that up and ran it like that for years.
