Marklorenzo
Hello everyone. I have a 1978 XS500 that I am working on. When purchased the carbs were complete junk. PO tried to remove pilot jets and drilled into them and destroyed them. So instead of trying to fix something that could probably not be fixed, I purchased a set of VM34s. The carbs fit into my carb holders snug at first, but it seems I have to really tighten the clamps down to make them somewhat snug. Not tight enough for rider comfort. Any ideas on what holders would work? Also, I purchased a 1 into 2 throttle cable from Carb Parts Warehouse along with a new throttle. I installed cable and it seems as though I do not have enough length on the carb end for full push and pull. Same at the throttle housing, seems to be getting stuck or not enough push pull for full movement. I can get the carbs to sit at half throttle open and close no problem, but no full range. I barely had enough room to attach cable to slide. Any ideas on this?
